Introduzione
A brief guide on how to replace the battery for your Palm V
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Lay screen face down so the battery is facing upwards.
Cover the upper back portion of the device so the battery is the only exposed part.
Altre 3 persone hanno completato questa guida.
