Salta al contenuto principale
Palm m 100 Cover Replacement
Cosa ti serve
  1. Palm m 100 Cover Replacement, Cover: passo 1, immagine 1 di 1
    • Remove the batteries.
  2. Palm m 100 Cover Replacement: passo 2, immagine 1 di 1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Cover Replacement: passo 3, immagine 1 di 3 Palm m 100 Cover Replacement: passo 3, immagine 2 di 3 Palm m 100 Cover Replacement: passo 3, immagine 3 di 3
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  4. Palm m 100 Cover Replacement: passo 4, immagine 1 di 1
    • Set aside broken cover, and replace with a new cover.
  5. Palm m 100 Cover Replacement: passo 5, immagine 1 di 1
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  6. Palm m 100 Cover Replacement: passo 6, immagine 1 di 1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Conclusione
Anne Carey
Membro da: 10/25/11
1 Reputazione
3 Guide realizzate
James Madison, Team 1-3, Allen Fall 2011 Membro di James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 547
