Salta al contenuto principale
Palm Zire 71 Battery Replacement
Cosa ti serve
  1. Palm Zire 71 Battery Replacement, Preparation: passo 1, immagine 1 di 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Battery Replacement, Top Screws (2) Removal: passo 2, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Battery Replacement, Bottom Screws (3) Removal: passo 3, immagine 1 di 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Battery Replacement, Front Panel Removal: passo 4, immagine 1 di 2 Palm Zire 71 Battery Replacement, Front Panel Removal: passo 4, immagine 2 di 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: passo 5, immagine 1 di 2 Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: passo 5, immagine 2 di 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Battery Replacement, Back Cover: passo 6, immagine 1 di 2 Palm Zire 71 Battery Replacement, Back Cover: passo 6, immagine 2 di 2
    • Slide the back cover off.
  7. Palm Zire 71 Battery Replacement, Battery: passo 7, immagine 1 di 1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Battery Replacement: passo 8, immagine 1 di 2 Palm Zire 71 Battery Replacement: passo 8, immagine 2 di 2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Battery Replacement: passo 9, immagine 1 di 3 Palm Zire 71 Battery Replacement: passo 9, immagine 2 di 3 Palm Zire 71 Battery Replacement: passo 9, immagine 3 di 3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Battery Replacement: passo 10, immagine 1 di 3 Palm Zire 71 Battery Replacement: passo 10, immagine 2 di 3 Palm Zire 71 Battery Replacement: passo 10, immagine 3 di 3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
Conclusione
Altre 7 persone hanno completato questa guida.
Jinxian Jiang
Membro da: 04/28/11
245 Reputazione
3 Guide realizzate
Un commento
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 9,112
