Salta al contenuto principale
Palm Zire 31 Speaker Replacement
Cosa ti serve
  1. Palm Zire 31 Speaker Replacement, Case: passo 1, immagine 1 di 1
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Speaker Replacement: passo 2, immagine 1 di 1
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Speaker Replacement: passo 3, immagine 1 di 1
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Speaker Replacement: passo 4, immagine 1 di 1
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
    • Desolder the speaker wires and solder the new speaker in its place.
    • The black and red wires are connected to the two solder bulbs in the yellow box.
Conclusione
Gabe
Membro da: 01/23/11
501 Reputazione
5 Guide realizzate
Cal Poly, Team 5-21, Amido Winter 2011 Membro di Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 593
