Introduzione
Remove the keyboard in order to replace the rubber button pad, keypad, or keyboard circuit.
Parti
Nessuna parte richiesta.
  1. Press the button on the back cover to release the battery cover. Slide off the battery cover. Slide off the battery cover.
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Remove the battery by lifting up on one side. Remove the battery by lifting up on one side.
    • Remove the battery by lifting up on one side.
  3. Remove the stylus by pulling up on the large top to reveal the top left case screw. Pull away the black flap to reveal the top right case screw.
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. WARNING: The top right red screw marked by the red circle has a warranty seal. Removing this seal will void your warranty.
    • WARNING: The top right red screw marked by the red circle has a warranty seal. Removing this seal will void your warranty.
    • Use the T5 screwdriver attachment to remove the 5 black back case screws marked by the red and yellow circles. These screws are 0.274 inches long.
    • Use the same T5 screwdriver attachment to remove the middle screw marked by the blue circle. It is shorter than the other screws at 0.121 inches in length.
  5. Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top. ATTENTION: Side volume control buttons may fall out after opening the device.
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • ATTENTION: Side volume control buttons may fall out after opening the device.
  6. Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the yellow box. WARNING: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the yellow box.
    • WARNING: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  8. Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves. Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves. Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  9. Gently peel off the protective yellow tape covering the ribbon cable using tweezers or your fingers.
    • Gently peel off the protective yellow tape covering the ribbon cable using tweezers or your fingers.
    • ATTENTION: Save the tape for reassembly.
  10. Using tweezers flip up the black plastic snap covering the small ribbon cable. Using tweezers gently pull out the ribbon cable to detach it from the circuit board.
    • Using tweezers flip up the black plastic snap covering the small ribbon cable.
    • Using tweezers gently pull out the ribbon cable to detach it from the circuit board.
  11. With the screen facing down. Use the Phillips 00 screwdriver attachment to remove the silver, 0.124 inch long screw on the left side of the circuit board above the ribbon cable.
    • With the screen facing down. Use the Phillips 00 screwdriver attachment to remove the silver, 0.124 inch long screw on the left side of the circuit board above the ribbon cable.
    • WARNING: Do not over-tighten the screw during reassembly.
  12. Pivot the circuit board away from the casing keeping the screen face down. Gently peel away the tape holding the ribbon cable to the screen. ATTENTION: Save the tape for reassembly.
    • Pivot the circuit board away from the casing keeping the screen face down.
    • Gently peel away the tape holding the ribbon cable to the screen.
  13. Using tweezers flip up the black plastic snap covering the ribbon cable attached to the screen. Gently pull out the ribbon cable freeing the circuit board from the casing.
    • Using tweezers flip up the black plastic snap covering the ribbon cable attached to the screen.
    • Gently pull out the ribbon cable freeing the circuit board from the casing.
  14. Separate the circuit board from front cover. Separate the circuit board from front cover.
    • Separate the circuit board from front cover.
  15. Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front. Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front.
    • Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front.
  16. Using the Phillips 00 screwdriver attachment remove the two silver, 0.121 inch long screws connecting the keypad to the casing.
    • Using the Phillips 00 screwdriver attachment remove the two silver, 0.121 inch long screws connecting the keypad to the casing.
    • WARNING: Do not over-tighten the screws during reassembly or the keyboard will not work properly.
  17. Lift the metal keyboard backing from underneath the metal straps and slide it out backwards away from the casing.
    • Lift the metal keyboard backing from underneath the metal straps and slide it out backwards away from the casing.
  18. Lift up and remove the transparent rubber key liner.
    • Lift up and remove the transparent rubber key liner.
  19. Lift up and remove the rubber keypad and button pads. Lift up and remove the rubber keypad and button pads. Lift up and remove the rubber keypad and button pads.
    • Lift up and remove the rubber keypad and button pads.
Conclusione
Mike Shaw
Membro da: 03/01/2011
601 Reputazione
6 Guide realizzate
Cal Poly, Team 14-6, Forte Winter 2011 Membro di Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Membri
12 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,915
