Salta al contenuto principale
Palm Treo 755p Back Cover Replacement
Cosa ti serve
  1. Palm Treo 755p Back Cover Replacement, Battery: passo 1, immagine 1 di 3 Palm Treo 755p Back Cover Replacement, Battery: passo 1, immagine 2 di 3 Palm Treo 755p Back Cover Replacement, Battery: passo 1, immagine 3 di 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Back Cover Replacement: passo 2, immagine 1 di 2 Palm Treo 755p Back Cover Replacement: passo 2, immagine 2 di 2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Back Cover Replacement, Back Cover: passo 3, immagine 1 di 2 Palm Treo 755p Back Cover Replacement, Back Cover: passo 3, immagine 2 di 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Back Cover Replacement: passo 4, immagine 1 di 1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Back Cover Replacement: passo 5, immagine 1 di 2 Palm Treo 755p Back Cover Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Back Cover Replacement: passo 6, immagine 1 di 2 Palm Treo 755p Back Cover Replacement: passo 6, immagine 2 di 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Back Cover Replacement: passo 7, immagine 1 di 3 Palm Treo 755p Back Cover Replacement: passo 7, immagine 2 di 3 Palm Treo 755p Back Cover Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
Conclusione
Mike Shaw
Membro da: 01/03/11
601 Reputazione
6 Guide realizzate
Cal Poly, Team 14-6, Forte Winter 2011 Membro di Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,566
