Salta al contenuto principale
Palm Treo 700P LCD Replacement
Cosa ti serve
  1. Palm Treo 700P LCD Replacement, Battery: passo 1, immagine 1 di 3 Palm Treo 700P LCD Replacement, Battery: passo 1, immagine 2 di 3 Palm Treo 700P LCD Replacement, Battery: passo 1, immagine 3 di 3
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P LCD Replacement: passo 2, immagine 1 di 2 Palm Treo 700P LCD Replacement: passo 2, immagine 2 di 2
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P LCD Replacement, Back Case: passo 3, immagine 1 di 1
    • Remove the stylus from the phone.
  4. Palm Treo 700P LCD Replacement: passo 4, immagine 1 di 1
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P LCD Replacement: passo 5, immagine 1 di 1
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P LCD Replacement: passo 6, immagine 1 di 1
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P LCD Replacement: passo 7, immagine 1 di 2 Palm Treo 700P LCD Replacement: passo 7, immagine 2 di 2
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P LCD Replacement, Motherboard: passo 8, immagine 1 di 3 Palm Treo 700P LCD Replacement, Motherboard: passo 8, immagine 2 di 3 Palm Treo 700P LCD Replacement, Motherboard: passo 8, immagine 3 di 3
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P LCD Replacement: passo 9, immagine 1 di 3 Palm Treo 700P LCD Replacement: passo 9, immagine 2 di 3 Palm Treo 700P LCD Replacement: passo 9, immagine 3 di 3
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P LCD Replacement: passo 10, immagine 1 di 2 Palm Treo 700P LCD Replacement: passo 10, immagine 2 di 2
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P LCD Replacement: passo 11, immagine 1 di 3 Palm Treo 700P LCD Replacement: passo 11, immagine 2 di 3 Palm Treo 700P LCD Replacement: passo 11, immagine 3 di 3
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
  12. Palm Treo 700P LCD Replacement, LCD: passo 12, immagine 1 di 1
    • Once the motherboard is removed, the LCD should be resting on the front case of the phone.
Conclusione
Lucas
Membro da: 04/17/12
26 Reputazione
1 Guida realizzata
Cal Poly, Team 12-37, Regan Spring 2012 Membro di Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 873
