Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Follow this guide to access and remove the antenna of the cell phone.
  1. Press the button located just above the Sprintâ„¢ logo and then slide the cover down. Press the button located just above the Sprintâ„¢ logo and then slide the cover down. Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
    • Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
  2. Use the small notch on the left hand side of the phone to remove the battery. Use the small notch on the left hand side of the phone to remove the battery.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Remove the stylus from the phone.
    • Remove the stylus from the phone.
  4. After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
    • After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
  5. Using the spudger, remove the small rubberized patch under the antenna.
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Unscrew the last two screws using the same T-5 Torx screw driver.
    • Unscrew the last two screws using the same T-5 Torx screw driver.
  7. Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
    • Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
  8. The antenna will now be loose, gently pull the antenna out of the phone.
    • The antenna will now be loose, gently pull the antenna out of the phone.
Conclusione
Cal Poly, Team 12-37, Regan Spring 2012 Membro di Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 724
