Introduzione
This guide will show you how to remove and repair a malfunctioning LCD Screen/Touch Screen on a Palm Treo 680 with 4 steps.
Cosa ti serve
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use a pair of tweezers, to carefully peel off the silver tape from the screen.
Push the screen out of the back of the front panel to remove it.
To reassemble your device, follow these instructions in reverse order, but ensure you use the new screen. Take your e-waste to an R2 or e-Stewards certified recycler.
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
