Salta al contenuto principale
Palm Treo 650 Earphone Replacement
Cosa ti serve
  1. Palm Treo 650 Earphone Replacement, Battery and Stylus: passo 1, immagine 1 di 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Earphone Replacement: passo 2, immagine 1 di 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Earphone Replacement: passo 3, immagine 1 di 2 Palm Treo 650 Earphone Replacement: passo 3, immagine 2 di 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Earphone Replacement, Case: passo 4, immagine 1 di 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Earphone Replacement: passo 5, immagine 1 di 2 Palm Treo 650 Earphone Replacement: passo 5, immagine 2 di 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Earphone Replacement: passo 6, immagine 1 di 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Earphone Replacement: passo 7, immagine 1 di 2 Palm Treo 650 Earphone Replacement: passo 7, immagine 2 di 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Earphone Replacement, Motherboard: passo 8, immagine 1 di 3 Palm Treo 650 Earphone Replacement, Motherboard: passo 8, immagine 2 di 3 Palm Treo 650 Earphone Replacement, Motherboard: passo 8, immagine 3 di 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Earphone Replacement: passo 9, immagine 1 di 2 Palm Treo 650 Earphone Replacement: passo 9, immagine 2 di 2
    • Pull off the motherboard.
  10. Palm Treo 650 Earphone Replacement, Earphone: passo 10, immagine 1 di 3 Palm Treo 650 Earphone Replacement, Earphone: passo 10, immagine 2 di 3 Palm Treo 650 Earphone Replacement, Earphone: passo 10, immagine 3 di 3
    • Pull out the earphone by grabbing the black rubber piece identified in the picture.
Conclusione
cgood
Membro da: 10/28/09
122 Reputazione
7 Guide realizzate
Cal Poly, Team 19-3, Maness Fall 2009 Membro di Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,995
