Introduzione
Replace the speaker
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  5. Using the spudger, pull the speaker straight up.
    • Using the spudger, pull the speaker straight up.
  6. Gently pull the rubber coating off of the speaker.
    • Gently pull the rubber coating off of the speaker.
Conclusione
Clement Poisson
Membro da: 26/01/2010
24 Reputazione
7 Guide realizzate
Cal Poly, Team 13-23, Maness Winter 2010 Membro di Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,454
