Salta al contenuto principale
Palm Treo 600 Logic Board Replacement
Cosa ti serve
  1. Palm Treo 600 Logic Board Replacement, Back Case: passo 1, immagine 1 di 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Logic Board Replacement: passo 2, immagine 1 di 2 Palm Treo 600 Logic Board Replacement: passo 2, immagine 2 di 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Logic Board Replacement: passo 3, immagine 1 di 2 Palm Treo 600 Logic Board Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Logic Board Replacement, Motherboard: passo 4, immagine 1 di 1
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Palm Treo 600 Logic Board Replacement: passo 5, immagine 1 di 1
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. Palm Treo 600 Logic Board Replacement: passo 6, immagine 1 di 1
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Palm Treo 600 Logic Board Replacement: passo 7, immagine 1 di 2 Palm Treo 600 Logic Board Replacement: passo 7, immagine 2 di 2
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Conclusione
Cal Poly, Team 13-23, Maness Winter 2010 Membro di Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,526
