Introduzione
Replace the keyboard!!
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
    • Using the spudger, flip open the clasp that holds the data ribbon in place.
    • Pull out the ribbon.
    • The keyboard will disconnect from the phone.
Conclusione
Clement Poisson
Membro da: 26/01/2010
24 Reputazione
7 Guide realizzate
Cal Poly, Team 13-23, Maness Winter 2010 Membro di Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membri
16 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,414
