Introduzione
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
    • Using the flat end of the spudger, lift the metal case off of the camera.
    • Slide the flat end of the spudger between the printed circuit board and metal holder.
    • Pop the camera up
Conclusione
Clement Poisson
Membro da: 26/01/2010
24 Reputazione
7 Guide realizzate
Cal Poly, Team 13-23, Maness Winter 2010 Membro di Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membri
16 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,479
