Introduzione
This guide will walk you through the steps to remove and replace the front panel on a Palm T|X.
Cosa ti serve
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
Orient the device sideways, as shown in the picture.
Lightly push the front of the display to separate it from the front panel.
Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
Altre 2 persone hanno completato questa guida.
