Salta al contenuto principale
Palm TX Back Panel Replacement
Cosa ti serve
  1. Palm TX Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Palm TX Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Back Panel Replacement: passo 2, immagine 1 di 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Back Panel Replacement: passo 3, immagine 1 di 2 Palm TX Back Panel Replacement: passo 3, immagine 2 di 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Back Panel Replacement: passo 4, immagine 1 di 2 Palm TX Back Panel Replacement: passo 4, immagine 2 di 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Back Panel Replacement: passo 5, immagine 1 di 2 Palm TX Back Panel Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
Conclusione
Cal Poly, Team 1-15, Amido Winter 2011 Membro di Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,569
