Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Follow this disassembly to remove the top casing of your laptop.
Parti
Nessuna parte specificata.
  1. Turn power off using the power button located in the top left corner of the  keyboard. Press and hold the power button for 3 seconds until it turns off.
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop. Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. Locate the battery and the two switches that release the battery when they are unlocked. Locate the battery and the two switches that release the battery when they are unlocked.
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible. Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port. While holding the switch in place, use your right hand to gently remove the battery from its port. While holding the switch in place, use your right hand to gently remove the battery from its port.
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
    • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
  7. Pry up and detach keyboard.
    • Pry up and detach keyboard.
  8. Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
    • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
  9. Remove the palm rest using the blue spudger tool. Remove the palm rest using the blue spudger tool.
    • Remove the palm rest using the blue spudger tool.
  10. Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
    • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
  11. Remove metal keyboard underlayment.
    • Remove metal keyboard underlayment.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 610
