Salta al contenuto principale
Palm Pre Speaker Replacement
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Palm Pre Speaker Replacement, Antenna: passo 1, immagine 1 di 2 Palm Pre Speaker Replacement, Antenna: passo 1, immagine 2 di 2
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre Speaker Replacement: passo 2, immagine 1 di 2 Palm Pre Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre Speaker Replacement: passo 3, immagine 1 di 2 Palm Pre Speaker Replacement: passo 3, immagine 2 di 2
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
  4. Palm Pre Speaker Replacement, Speaker: passo 4, immagine 1 di 3 Palm Pre Speaker Replacement, Speaker: passo 4, immagine 2 di 3 Palm Pre Speaker Replacement, Speaker: passo 4, immagine 3 di 3
    • With the backplate removed, the speaker is visible.
    • Pry out speaker with spudger.
    • It is magnetically attached so there should be a little bit of resistance; however, there are no wires to disconnect.
    • Take note of the orientation of the speaker for re-installation.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 312
