Introduzione
The following guide will show the reader how to properly remove the motherboard from the Palm Pre 2.
  1. Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Pull on the tab to remove the battery.
    • Pull on the tab to remove the battery.
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas (Reference the red box in the image).
    • Use tweezers to remove the two antennas from the keypad control board.
    • Use the opening tool to pry off the (black and yellow) back frame.
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
    • Use tweezers to separate the keyboard from the phone.
    • Use a Phillips #0 screwdriver to remove the remaining 4 screws from the main portion of the phone.
    • Use an opening tool to remove the motherboard.
Conclusione
Cole Simmerman
Membro da: 08/01/2018
160 Reputazione
1 Guida realizzata
IUPUI, Team S1-G6, Freund Spring 2018 Membro di IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 Membri
4 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
