Introduzione
The motherboard contains the CPU, hot sync port, and infrared port. If any of these things aren't working, the motherboard may need to be replaced.
This guide will show you how to replace the motherboard of your Palm IIIxe.
Cosa ti serve
Turn the device over so it is face down and remove the stylus, and battery cover.
Using a Philips #0 or #00 screwdriver, locate and unscrew the four screws holding the back cover on the device.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Locate the brown serial connector on the left side of the device. Using the flat head screw driver, push the little tabs (one on each side) out towards you as pictured.
They should extend about 1/16 of an inch (1.5 mm).
Now take the screwdriver/tweezers and gently pry out the serial tab as shown .
Take the plastic opening tool and gently pry the circuit board out of the plastic tabs around the perimeter located as shown.
You must also pry the circuit board away from the battery case (picture 2).
Now gently lift up the circuit board from the right side and set it on the cloth.
