Salta al contenuto principale
Pacific Image Electronics CS3600 Screen Replacement
Cosa ti serve
  1. Pacific Image Electronics CS3600 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Screen Replacement: passo 2, immagine 1 di 1
    • With light force, open the scanner at the seam.
  3. Pacific Image Electronics CS3600 Screen Replacement: passo 3, immagine 1 di 2 Pacific Image Electronics CS3600 Screen Replacement: passo 3, immagine 2 di 2
    • Push the screen away from the scanner from the inside with light force until it is no longer attached.
    • Replace with a new screen.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 285
