Salta al contenuto principale
Pacific Image Electronics CS3600 Motor Replacement
Cosa ti serve
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: passo 1, immagine 1 di 2 Pacific Image Electronics CS3600 Motor Replacement, Motor: passo 1, immagine 2 di 2
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: passo 2, immagine 1 di 1
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: passo 3, immagine 1 di 1
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: passo 4, immagine 1 di 2 Pacific Image Electronics CS3600 Motor Replacement: passo 4, immagine 2 di 2
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: passo 5, immagine 1 di 1
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 265
