Salta al contenuto principale
Pacific Image Electronics CS3600 Lens Replacement
Cosa ti serve
  1. Pacific Image Electronics CS3600 Lens Replacement, Lens: passo 1, immagine 1 di 2 Pacific Image Electronics CS3600 Lens Replacement, Lens: passo 1, immagine 2 di 2
    • Use the J0 screwdriver to remove the 5 following screws that are 9 mm x 7 mm.
  2. Pacific Image Electronics CS3600 Lens Replacement: passo 2, immagine 1 di 1
    • Using light force open the device by pulling at the seam.
  3. Pacific Image Electronics CS3600 Lens Replacement: passo 3, immagine 1 di 1
    • Use the J0 screwdriver to remove the screws that are 7 mm x 6 mm.
  4. Pacific Image Electronics CS3600 Lens Replacement: passo 4, immagine 1 di 1
    • Once the screws are removed and casing removed the lens is revealed.
  5. Pacific Image Electronics CS3600 Lens Replacement: passo 5, immagine 1 di 1
    • Simply remove the lens and replace accordingly!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 228
