Salta al contenuto principale
Pac-Man Connect and Play Joystick Switchboard Replacement
Cosa ti serve
  1. Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: passo 1, immagine 1 di 2 Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: passo 1, immagine 2 di 2
    • Flip over the device
    • Ensure the device has no power and is not plugged into a TV
  2. Pac-Man Connect and Play Joystick Switchboard Replacement: passo 2, immagine 1 di 1
    • Remove these 5 Phillips Head screws
  3. Pac-Man Connect and Play Joystick Switchboard Replacement: passo 3, immagine 1 di 2 Pac-Man Connect and Play Joystick Switchboard Replacement: passo 3, immagine 2 di 2
    • You can now open the device
  4. Pac-Man Connect and Play Joystick Switchboard Replacement: passo 4, immagine 1 di 1
    • Remove these 2 screws (phillips)
  5. Pac-Man Connect and Play Joystick Switchboard Replacement: passo 5, immagine 1 di 3 Pac-Man Connect and Play Joystick Switchboard Replacement: passo 5, immagine 2 di 3 Pac-Man Connect and Play Joystick Switchboard Replacement: passo 5, immagine 3 di 3
    • You can now remove the board
    • You can, at this time, also remove the plastic X that holds the joystick spring in place.
Conclusione
[deleted]
Membro da: 07/13/18
4.656 Reputazione
25 Guide realizzate
1Commento della guida
My husband ordered a new control board. And it worked for a couple of days. Now the control stick will get caught and will not turn to go around maze🙁.
What should we do? HELP Please.
Cathi M Gautney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 840
