Introduzione
This guide shows how to remove the PSP Go's battery.
Cosa ti serve
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use a plastic opening tool to gently flip up the left trigger connector.
Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
Altre 17 persone hanno completato questa guida.
9 Commenti
this was so quick . I have been trying to get this repaired for years, only to hear throw it away there is no fix . sharing love
a couple of notes my cover came completely off in the beginning step without a problem or broken screws. next i didnt und the wired cabled beside the clicker and it wasnt in the way.
After replace a new battery my psp go going crazy. Charge only 1 or 2 min led going to green but not fully charge. Anyone can help me to fix this
Cfw 6.61 pro update. Helppp
Thanks to this guide I was able to reseat the battery, the PSP was not turning on or charging any more, now everything is working again.
Excellent guide, PSP go works like new!
I bought a replacement battery online for my PSP Go, but it came without the white connector. Have you an idea how to fix it?
My psp go is not charging but when I connect it my laptop is get connected any idea what is going on
I knew how to do it but I love this site and it does help
