Salta al contenuto principale
PSP E1000 Battery Replacement
Cosa ti serve
  1. PSP E1000 Battery Replacement, Battery: passo 1, immagine 1 di 2 PSP E1000 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • To start the replacement flip the device over
  2. PSP E1000 Battery Replacement: passo 2, immagine 1 di 2 PSP E1000 Battery Replacement: passo 2, immagine 2 di 2
    • We are going to start by removing the back panel.
    • To do this open the panel and gently squeeze in the UMD tray until it pops up.
    • It should lay flat against the back panel while open if done correctly
  3. PSP E1000 Battery Replacement: passo 3, immagine 1 di 2 PSP E1000 Battery Replacement: passo 3, immagine 2 di 2
    • Gently bend the back panel to free the hinge on the left.
    • Once it is popped out it should look like the second photo
    • The back panel can then be slid off
  4. PSP E1000 Battery Replacement: passo 5, immagine 1 di 3 PSP E1000 Battery Replacement: passo 5, immagine 2 di 3 PSP E1000 Battery Replacement: passo 5, immagine 3 di 3
    • Remove the screw with a #00 Philips and slide up the battery cover.
    • The battery can now be removed by pulling it out.
    • When reinstalling, it is useful to use a spudger to push the cable back in.
    • Congratulations you have replaced your PSP E1000's battery
Conclusione
Caleb Pierce
Membro da: 04/19/22
230 Reputazione
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 32
Tutti i Tempi: 32
