Salta al contenuto principale
PSP 300xc Trigger Buttons Replacement
Cosa ti serve
  1. PSP 300xc Trigger Buttons Replacement, Battery: passo 1, immagine 1 di 2 PSP 300xc Trigger Buttons Replacement, Battery: passo 1, immagine 2 di 2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
    Chiedi a FixBot
  2. PSP 300xc Trigger Buttons Replacement, Front Case: passo 2, immagine 1 di 1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
    Chiedi a FixBot
  3. PSP 300xc Trigger Buttons Replacement: passo 3, immagine 1 di 2 PSP 300xc Trigger Buttons Replacement: passo 3, immagine 2 di 2
    • Remove four Phillips screws from the back of the PSP.
    Chiedi a FixBot
  4. PSP 300xc Trigger Buttons Replacement: passo 4, immagine 1 di 1
    • Remove two Phillips screws from the top of the PSP.
    Chiedi a FixBot
  5. PSP 300xc Trigger Buttons Replacement: passo 5, immagine 1 di 1
    • Remove a single screw from the bottom edge of the PSP.
    Chiedi a FixBot
  6. PSP 300xc Trigger Buttons Replacement: passo 6, immagine 1 di 2 PSP 300xc Trigger Buttons Replacement: passo 6, immagine 2 di 2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
    Chiedi a FixBot
  7. PSP 300xc Trigger Buttons Replacement, LCD: passo 7, immagine 1 di 1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
    Chiedi a FixBot
  8. PSP 300xc Trigger Buttons Replacement: passo 8, immagine 1 di 2 PSP 300xc Trigger Buttons Replacement: passo 8, immagine 2 di 2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
    Chiedi a FixBot
  9. PSP 300xc Trigger Buttons Replacement: passo 9, immagine 1 di 1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
    Chiedi a FixBot
  10. PSP 300xc Trigger Buttons Replacement: passo 10, immagine 1 di 1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
    Chiedi a FixBot
  11. PSP 300xc Trigger Buttons Replacement: passo 11, immagine 1 di 3 PSP 300xc Trigger Buttons Replacement: passo 11, immagine 2 di 3 PSP 300xc Trigger Buttons Replacement: passo 11, immagine 3 di 3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
    Chiedi a FixBot
  12. PSP 300xc Trigger Buttons Replacement: passo 12, immagine 1 di 1
    • Remove the LCD from the PSP 300xc.
    Chiedi a FixBot
  13. PSP 300xc Trigger Buttons Replacement, Home Bar: passo 13, immagine 1 di 3 PSP 300xc Trigger Buttons Replacement, Home Bar: passo 13, immagine 2 di 3 PSP 300xc Trigger Buttons Replacement, Home Bar: passo 13, immagine 3 di 3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
    Chiedi a FixBot
  14. PSP 300xc Trigger Buttons Replacement, Trigger Buttons: passo 14, immagine 1 di 2 PSP 300xc Trigger Buttons Replacement, Trigger Buttons: passo 14, immagine 2 di 2
    • Remove both trigger buttons by lifting them off the PSP 300xc.
    Chiedi a FixBot
Conclusione
Matthew Newsom
Membro da: 01/05/10
42.700 Reputazione
67 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 23
Ultimi 30 giorni: 96
Tutti i Tempi: 3,257
