Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Guide for removing the power jack from a Sony PSP-3000
  1. Place the PSP face down and locate the battery cover on the left side of the device. Lift and remove the battery cover to reveal the battery. Remove the battery.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Replica
  3. Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver. Two are located behind the battery's warranty sticker.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. Next, unscrew the two screws located at the top of the PSP.
    • Next, unscrew the two screws located at the top of the PSP.
  5. Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  7. Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
 Remove the front casing completely.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  8. Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  9. Slowly lift the LCD screen off the PSP starting at the top edge corner. Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
  10. Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail. Pull all four ribbon cables out.
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    For anyone struggling to get the screen’s smaller ribbon cable back in, don’t be too afraid to use tweezers to pull on the little tabs. It has to go in a good half way (of the darker area) in order for you to latch it without it falling back out.
    Tom - Replica
  11. Remove the metal tab that lies above the LCD screen.
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  12. Flip up the lock and detach the ribbon cable above the power jack.
    • Flip up the lock and detach the ribbon cable above the power jack.
  13. Remove the screw from the power jack.
    • Remove the screw from the power jack.
  14. Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    The plastic tab in this step is very fragile. Use care when bending the plastic tab back.
    Kris - Replica
  15. Pull the plug connecting the power jack to the motherboard.
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
Conclusione
Altre 7 persone hanno completato questa guida.
mbnewsom
Membro da: 28/10/2009
2.668 Reputazione
11 Guide realizzate
Really easy to follow, thanks. You can dismiss the 10 and 11 steps being careful.
aONe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 70
Tutti i Tempi: 12,625
