Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Steps for replacing malfunctioned directional pads in a Sony PSP-3000
  1. Place the PSP face down and locate the battery cover on the left side of the device. Lift and remove the battery cover to reveal the battery. Remove the battery.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Replica
  3. Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver. Two are located behind the battery's warranty sticker.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Next, unscrew the two screws located at the top of the PSP.
    • Next, unscrew the two screws located at the top of the PSP.
  6. Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  7. Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
 Remove the front casing completely.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  8. Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing. Remove the D-pad and the rubber piece.
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
Conclusione
Altre 3 persone hanno completato questa guida.
mbnewsom
Membro da: 28/10/2009
2.668 Reputazione
11 Guide realizzate
Is it for 2000?
Kaio Igor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 41
Tutti i Tempi: 6,383
