Introduzione
Do your earphones only work as earmuffs? You may need to replace your PSP's audio jack.
Cosa ti serve
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
Use the opening tools to press the tab on the left-hand side of the speaker to release it.
Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
Slide off the left trigger along with the plastic bracket underneath.
Carefully pry off left trigger button using opening tools.
Remove the following four connections:
Two ribbon cables -- flip up latch and remove horizontally.
One wire clamp -- use an opening tool to pry it up vertically.
One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
With the logic board out of the way, remove the 4mm Phillips screw.
Carefully lift the headphone jack out of the casing.
Carefully lift headphone jack out of casing.
Altre 4 persone hanno completato questa guida.
