Introduzione
Questa guida ti mostrerà come rimuovere la scocca/cornice della PSP.
Cosa ti serve
Cerca il bottone del coperchio della batteria a sinistra sul retro della PSP.
Premi il bottone e rimuovi il coperchio.
You are dumbbb... BRO YOUR DUMB BC U DIDNT HAVE TO USE A TOOL TO OPEN THE DOOR. USE YOUR FINGER""
The battery door can be damaged dont use a tool
That also happend to me it got destroyed by screwdriver
Usando un dito, rimuovi la batteria tenendo la console come mostrato nell'immagine.
The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
Rimuovi le quattro viti indicate con un cacciavite a croce di dimensioni #00.
you need to peel back the warranty sticker in order to access both the lower left and lower left screws
This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot.
Can't edit previous comment so here's a new one:
Standard or older iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot. You'll need precision bits that have longer tips to reach these deep screws.
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Altre 33 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
ToToMalux ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
3 Commenti
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
i also made a video on this for anyone who needs to do it that way.
