Salta al contenuto principale
PDP Victrix Pro BFG Battery and Trigger Replacement
Cosa ti serve
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: passo 1, immagine 1 di 1
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 2, immagine 1 di 1
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 3, immagine 1 di 2 PDP Victrix Pro BFG Battery and Trigger Replacement: passo 3, immagine 2 di 2
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 4, immagine 1 di 1
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 5, immagine 1 di 1
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 6, immagine 1 di 1
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 7, immagine 1 di 1
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 8, immagine 1 di 1
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 9, immagine 1 di 1
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
Conclusione
Altre 4 persone hanno completato questa guida.
ryanmorabito
Membro da: 03/20/24
260 Reputazione
1 Guida realizzata
4Commenti sulla guida
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - Replica
R2 and L2 no response, the board location for button?
Terry - Replica
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - Replica
How much and how can I buy the battery's?
Dino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 261
Tutti i Tempi: 4,817
