Salta al contenuto principale
PDP Rematch Advanced Trigger Springs Replacement
Cosa ti serve
  1. PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: passo 1, immagine 1 di 2 PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: passo 1, immagine 2 di 2
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Trigger Springs Replacement: passo 2, immagine 1 di 3 PDP Rematch Advanced Trigger Springs Replacement: passo 2, immagine 2 di 3 PDP Rematch Advanced Trigger Springs Replacement: passo 2, immagine 3 di 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Trigger Springs Replacement: passo 3, immagine 1 di 2 PDP Rematch Advanced Trigger Springs Replacement: passo 3, immagine 2 di 2
    • Twist the thumbstick to remove it from the motherboard.
  4. PDP Rematch Advanced Trigger Springs Replacement: passo 4, immagine 1 di 3 PDP Rematch Advanced Trigger Springs Replacement: passo 4, immagine 2 di 3 PDP Rematch Advanced Trigger Springs Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws that secure the motherboard.
    • Remove the motherboard from the back shell using moderate force.
  5. PDP Rematch Advanced Trigger Springs Replacement: passo 5, immagine 1 di 3 PDP Rematch Advanced Trigger Springs Replacement: passo 5, immagine 2 di 3 PDP Rematch Advanced Trigger Springs Replacement: passo 5, immagine 3 di 3
    • Punch out the metal pin holding in the trigger and the trigger spring. Repeat for both triggers.
    • Remove the trigger and the trigger springs.
    • Using a punch or a small tool allows pin removal to be easier.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 335
