Salta al contenuto principale
PDP Rematch Advanced Shoulder Buttons Replacement
Cosa ti serve
  1. PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: passo 1, immagine 1 di 3 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: passo 1, immagine 2 di 3 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: passo 1, immagine 3 di 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Shoulder Buttons Replacement: passo 2, immagine 1 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 2, immagine 2 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 2, immagine 3 di 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Shoulder Buttons Replacement: passo 3, immagine 1 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 3, immagine 2 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 3, immagine 3 di 3
    • Peel the rubber piece off the back of the face buttons.
  4. PDP Rematch Advanced Shoulder Buttons Replacement: passo 4, immagine 1 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 4, immagine 2 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 4, immagine 3 di 3
    • Push all the face buttons out from the front of the shell.
  5. PDP Rematch Advanced Shoulder Buttons Replacement: passo 5, immagine 1 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 5, immagine 2 di 3 PDP Rematch Advanced Shoulder Buttons Replacement: passo 5, immagine 3 di 3
    • Put two fingers behind the bumpers and push upwards to remove them.
  6. PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: passo 6, immagine 1 di 3 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: passo 6, immagine 2 di 3 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: passo 6, immagine 3 di 3
    • Push down on the trigger's long paddle.
    • Carefully twist the bumper out to remove it from the bumper frame.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 438
