Salta al contenuto principale
PDP Rematch Advanced Front Housing Shell Replacement
Cosa ti serve
  1. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: passo 1, immagine 1 di 3 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: passo 1, immagine 2 di 3 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: passo 1, immagine 3 di 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Chiedi a FixBot
  2. PDP Rematch Advanced Front Housing Shell Replacement: passo 2, immagine 1 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 2, immagine 2 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 2, immagine 3 di 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Chiedi a FixBot
  3. PDP Rematch Advanced Front Housing Shell Replacement: passo 3, immagine 1 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 3, immagine 2 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 3, immagine 3 di 3
    • Peel the rubber piece off the back of the face buttons.
    Chiedi a FixBot
  4. PDP Rematch Advanced Front Housing Shell Replacement: passo 4, immagine 1 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 4, immagine 2 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 4, immagine 3 di 3
    • Push all the face buttons out from the front of the shell.
    Chiedi a FixBot
  5. PDP Rematch Advanced Front Housing Shell Replacement: passo 5, immagine 1 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 5, immagine 2 di 3 PDP Rematch Advanced Front Housing Shell Replacement: passo 5, immagine 3 di 3
    • Put two fingers behind the bumpers and push upwards to remove them.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 55
Tutti i Tempi: 440
