Salta al contenuto principale
PDP Rematch Advanced Back Shell Replacement
Cosa ti serve
  1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: passo 1, immagine 1 di 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: passo 1, immagine 2 di 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: passo 1, immagine 3 di 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Chiedi a FixBot
  2. PDP Rematch Advanced Back Shell Replacement: passo 2, immagine 1 di 3 PDP Rematch Advanced Back Shell Replacement: passo 2, immagine 2 di 3 PDP Rematch Advanced Back Shell Replacement: passo 2, immagine 3 di 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Chiedi a FixBot
  3. PDP Rematch Advanced Back Shell Replacement: passo 3, immagine 1 di 2 PDP Rematch Advanced Back Shell Replacement: passo 3, immagine 2 di 2
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    Chiedi a FixBot
  4. PDP Rematch Advanced Back Shell Replacement, Back Shell: passo 4, immagine 1 di 2 PDP Rematch Advanced Back Shell Replacement, Back Shell: passo 4, immagine 2 di 2
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    Chiedi a FixBot
  5. PDP Rematch Advanced Back Shell Replacement: passo 5, immagine 1 di 2 PDP Rematch Advanced Back Shell Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    Chiedi a FixBot
  6. PDP Rematch Advanced Back Shell Replacement: passo 6, immagine 1 di 3 PDP Rematch Advanced Back Shell Replacement: passo 6, immagine 2 di 3 PDP Rematch Advanced Back Shell Replacement: passo 6, immagine 3 di 3
    • Remove the motherboard from the back shell using moderate force.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 48
Tutti i Tempi: 485
