Salta al contenuto principale
PDP Rematch Action Buttons Replacement
Cosa ti serve
  1. PDP Rematch Action Buttons Replacement, Faceplate: passo 1, immagine 1 di 2 PDP Rematch Action Buttons Replacement, Faceplate: passo 1, immagine 2 di 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Action Buttons Replacement: passo 2, immagine 1 di 2 PDP Rematch Action Buttons Replacement: passo 2, immagine 2 di 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Action Buttons Replacement: passo 3, immagine 1 di 2 PDP Rematch Action Buttons Replacement: passo 3, immagine 2 di 2
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Action Buttons Replacement, Action Buttons: passo 4, immagine 1 di 1
    • Optional: Use a cotton pad or cotton swab with some alcohol to gently clean any debris.
    • These buttons are not connected to the device and will fall out, so be careful.
  5. PDP Rematch Action Buttons Replacement: passo 5, immagine 1 di 3 PDP Rematch Action Buttons Replacement: passo 5, immagine 2 di 3 PDP Rematch Action Buttons Replacement: passo 5, immagine 3 di 3
    • Carefully remove the buttons from the device and set them aside.
    • From here, you can do a deeper clean, or replace them.
    • The clear plate will not sit right or click into place if the buttons are not aligned straight.
Conclusione
Katie Barnes
Membro da: 01/17/24
85 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 53
Tutti i Tempi: 546
