Salta al contenuto principale
PDP Afterglow Wired Xbox 360 Controller Button Replacement
Cosa ti serve
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: passo 1, immagine 1 di 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: passo 1, immagine 2 di 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 3, immagine 1 di 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: passo 4, immagine 1 di 1
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 5, immagine 1 di 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 5, immagine 2 di 2
    • Push up on the buttons from the front and pull them out from the back.
Conclusione
Altre 4 persone hanno completato questa guida.
Joi Officer
Membro da: 09/17/15
298 Reputazione
2 Guide realizzate
IUPUI, Team 3-1, Harley Fall 2015 Membro di IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Membri
5 Guide realizzate
4Commenti sulla guida
What about removing the Dpad? i really need help.
Elijah Douglas - Replica
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - Replica
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
David Drinkard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 64
Tutti i Tempi: 6,068
