Salta al contenuto principale
PDP Afterglow Fener Speaker Replacement
Cosa ti serve
  1. PDP Afterglow Fener Speaker Replacement, Speaker: passo 1, immagine 1 di 3 PDP Afterglow Fener Speaker Replacement, Speaker: passo 1, immagine 2 di 3 PDP Afterglow Fener Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps.
    • Remove the wire connected in the red box by gently pulling it off.
  2. PDP Afterglow Fener Speaker Replacement: passo 2, immagine 1 di 3 PDP Afterglow Fener Speaker Replacement: passo 2, immagine 2 di 3 PDP Afterglow Fener Speaker Replacement: passo 2, immagine 3 di 3
    • Take your soldering iron and unsolder the wire from the speaker.
    • The red square is the left tip and the orange square is the right tip.
    • Before wiring your new speaker in, clean the left and right tips with your soldering iron.
Conclusione
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,557
