Salta al contenuto principale
PDP Afterglow Fener Battery Replacement
Cosa ti serve
  1. PDP Afterglow Fener Battery Replacement, Battery: passo 1, immagine 1 di 2 PDP Afterglow Fener Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
  2. PDP Afterglow Fener Battery Replacement: passo 2, immagine 1 di 2 PDP Afterglow Fener Battery Replacement: passo 2, immagine 2 di 2
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
Conclusione
Altre 5 persone hanno completato questa guida.
Murat Terzi
Membro da: 10/26/15
215 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Membri
10 Guide realizzate
Un commento
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 7,459
