Salta al contenuto principale
PCIe Fan Replacement guide
Cosa ti serve
  1. PCIe Fan Replacement guide, Side Panel Removal: passo 1, immagine 1 di 1
    • Begin by pulling up on the lever located at the back of the computer to remove the side panel.
  2. PCIe Fan Replacement guide, Hard drive removal: passo 2, immagine 1 di 1
    • Gently pull outward on each of the four hard drive trays to remove them.
  3. PCIe Fan Replacement guide, Fan Removal: passo 3, immagine 1 di 1
    • Remove the two 10mm PH #1 screws holding in the PCIe fan.
    • They are very tightened, if you do it wrong the screw might get stripped.
  4. PCIe Fan Replacement guide, Fan Removal: passo 4, immagine 1 di 1
    • Gently pull the fan straight outward to remove it.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 59
Tutti i Tempi: 5,598
