Introduzione
If your Fragment Ozone 500 Mountain Bike rear tire is flat and losing air while not in use, this guide will show you how to replace the inner tube.
The tire tube needs to be replaced when you inflate the tire, and it deflates by itself. It does not need to be changed every time the tire is flat or needs air. Before you change the tire tube, try using a bike pump to add air and then let the bike sit without being ridden for a day or two. If the tire is flat again, then use this guide to replace the tube.
This step-by-step guide will help you if you need to change the tire on your Fragment Ozone 500 Mountain Bike. It demonstrates how to remove the tire from the frame, take the tube out from underneath the tire, replace the tube, and put the tire back onto the frame.
Cosa ti serve
On the left handle, there is the friction gear shift. While moving the pedals with your foot, turn the gear shift up to the lowest gear.
On the right handle, there is the seven speed gear shift. While moving the pedals with your foot, turn the gear shift down to the lowest gear.
Shift the chain onto the smallest rear cassette cog (the one farthest from the rear tire) and the smallest front chainring (the one farthest from the pedal).
Adjust the wrench to fit the size of the bolt holding the tire in place.
Once the wrench fits properly, place the wrench on the bolt. Turn the wrench to the left to loosen the bolt using your right hand while the left is holding the tire in place. Remove the wrench and keep repeating until the bolt comes off.
Repeat the last step for the bolt on the opposite side of the rear bike tire.
Use your non-dominant hand to squeeze the tire and lift it as much as you can to allow room for the tire lever.
Using your dominant hand, hold the tire lever and push it underneath the tire so it is flat against the rim.
Insert the second tire lever about six inches from the first, slide it under the tire, and lift to pop the tire over the rim.
Repeat the last step one more time and then you can slide the second lever along the inside of the tire and the rim until the tire is out of the rim.
Locate the air valve, and with your left hand, lift the tire up and away from the rim.
Use your right hand to pull the tube and the air valve up and out from underneath the tire. Pull the tire to the side of the tube to pull it out.
Once the air valve is out, pull the rest of the tube out from underneath the tire. Pull the tube towards you while rotating the rim and tire until the tube is completely out.
Place the bolt on the axel of the tire on each side.
Place the wrench on the bolt. Use your right hand to turn the wrench to the right to tighten the bolt while your left hand holds the tire in place.
Remove the wrench and repeat until the bolt can not get tighter.
Repeat this last step for the opposite side axel.
These are all of the steps to take tire off, replace tube, and put tire back on the bike
