Salta al contenuto principale
Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement
Cosa ti serve
    1. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Top Cover: passo 1, immagine 1 di 1
      • Undo the 7x PH2 Screw screws on the top case
      • You may need to remove the handle from the height adjustment. This mower was missing the handle
      • The top cover can be removed and set aside.
      • Always unplug the appliance before working on it.
      Chiedi a FixBot
      Aggiungi Commento
    2. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Wiring loom: passo 2, immagine 1 di 1
      • Disconnect the plug from the motor assembly
      Chiedi a FixBot
      Aggiungi Commento
    3. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Blade & Problem: passo 3, immagine 1 di 3 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Blade & Problem: passo 3, immagine 2 di 3 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Blade & Problem: passo 3, immagine 3 di 3
      • This mower has broke the piece that retains the bearing, then it snapped the belt. We are going to fix both problems
      • Turn the mower over and remove the blades so you are left with just the motor shaft. This mower already had the blades removed
      Chiedi a FixBot
      Aggiungi Commento
    4. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Motor Assembly: passo 4, immagine 1 di 2 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Motor Assembly: passo 4, immagine 2 di 2
      • Remove the 7x PH2 Screws holding the motor assembly to the main case
      • The motor and belt drive can now be removed from the lawn mower and set aside.
      Chiedi a FixBot
      Aggiungi Commento
    5. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Prepare the Housing: passo 5, immagine 1 di 2 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Prepare the Housing: passo 5, immagine 2 di 2
      • Remove the broken bearing retainer with side cutters and flush cutters if you have them
      • Using a wire brush on a drill, or a scraper, clean the housing to remove as much of the dirt and grass to prepare the housing for the new piece.
      • If you are not replacing the bearing retainer you can skip this step.
      Chiedi a FixBot
      Aggiungi Commento
    6. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Bearing Retainer: passo 6, immagine 1 di 1
      • 3D print a replacement bearing housing - File available online. Print in the strongest filament you have available. ABS, Nylon etc. Do not use PLA/PETG https://www.printables.com/model/1768728...
      • Alternatively I sell these on my website printed in PA12 Nylon-CF which is very strong and stiff. Perfectly suited for this application.
      • You may need to adjust the size of the bearing recess until it is a snug fit with a dremel or similar. Dont sand it too far otherwise it wont be a friction fit.
      • Using a hammer and a socket press the outer race of the 6902RS bearing into the bearing recess. I used a hydraulic press but thats overkill for this. It shouldnt take much force.
      • If your bearing retainer isnt broken, you can take this oppurtunity to install the new bearing into the housing
      Chiedi a FixBot
      Aggiungi Commento
    7. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Epoxy Gluing: passo 7, immagine 1 di 3 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Epoxy Gluing: passo 7, immagine 2 di 3 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Epoxy Gluing: passo 7, immagine 3 di 3
      • Position the bearing retainer as straight as you can inside the housing, you want it to be as perpendicular to the motor shaft as possible to reduce wear.
      • I used a 2 part epoxy, but any industrial strength glue should do the trick here. Something with a bit of thickness. Not super glue.
      Chiedi a FixBot
      Aggiungi Commento
    8. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement: passo 8, immagine 1 di 2 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement: passo 8, immagine 2 di 2
      • For extra security you can use the pre drilled holes in the model to drill some 3mm pilot holes into the housing. On an angle is fine.
      • Screw in some 6 gauge countersunk screws while the epoxy is drying to make the fit really strong.
      Chiedi a FixBot
      Aggiungi Commento
    9. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Other bearing replacements: passo 9, immagine 1 di 2 Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Other bearing replacements: passo 9, immagine 2 di 2
      • While you have the motor unit out you can replace the other two bearings.
      • There is a 10mm nut on the shaft end on the opposite end to where the belt pully is. Remove that and pull out the belt pulley and shaft.
      • Replace the 609RS & 6002RS Bearings in the motor housing
      Chiedi a FixBot
      Aggiungi Commento
    10. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Replace the belt: passo 10, immagine 1 di 1
      • Before putting the motor back into the housing - replace the belt if it is worn or damaged.
      • There is belt tensioning screws x4 on the motor pulley side to make it easier to replace the belt
      Chiedi a FixBot
      Aggiungi Commento
    11. Ozito 1500W Corded Lawn Mower ELM-1545 Belt and Bearing Replacement, Re-Assemble: passo 11, immagine 1 di 1
      • Once the glue is dried and you confirm it all fits you can reassemble everything in the reverse order.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 18
Ultimi 30 giorni: 54
Tutti i Tempi: 112
