Introduzione
We will be taking apart and looking at the components of the cordless Ovente Electric Kettle.
Cosa ti serve
Remove the three 11 mm screws from the center of the kettle's base using a Phillips #2 screwdriver.
Remove the one 15mm screw by the handle using a Phillips #2 screwdriver.
Unscrew the bottom chip and take it out of the handle. Use a #1 Phillips screwdriver to take out the 8.2 mm screw.
Then, weave it out the wires that were connected to the heating element and the thermal cutoff assembly through the handle base.
Remove the chip and it's soldered wires from the handle completely.
