Salta al contenuto principale
Ovente Electric Kettle KS88 Series Disassembly
Cosa ti serve
  1. Ovente Electric Kettle KS88 Series Disassembly, Ovente Electric Kettle KS88 Series Disassembly: passo 1, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly, Ovente Electric Kettle KS88 Series Disassembly: passo 1, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly, Ovente Electric Kettle KS88 Series Disassembly: passo 1, immagine 3 di 3
    • Remove the three 11 mm screws from the center of the kettle's base using a Phillips #2 screwdriver.
    • Remove the one 15mm screw by the handle using a Phillips #2 screwdriver.
  2. Ovente Electric Kettle KS88 Series Disassembly: passo 2, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 2, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 2, immagine 3 di 3
    • Remove the two 9 mm screws from either side of the round power receptacle using a Phillips #2 screwdriver.
    • Remove the washer beneath the screw on the left.
    • Remove the power receptacle from the device.
  3. Ovente Electric Kettle KS88 Series Disassembly: passo 3, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 3, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 3, immagine 3 di 3
    • Remove the yellow ground wire by pushing down on the small tab with your thumb and pulling.
    • Disconnect the black wires from the thermal cutoff assembly (the black box in the center) by jiggling and pulling outwards.
  4. Ovente Electric Kettle KS88 Series Disassembly: passo 4, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 4, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 4, immagine 3 di 3
    • Unfasten the nuts using a 5.5mm nut driver, and take out the thermal cutoff.
    • There is a washer under the nut on the top. Be sure to not lose it.
  5. Ovente Electric Kettle KS88 Series Disassembly: passo 5, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 5, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 5, immagine 3 di 3
    • Unscrew the three 8.0 mm Phillips #2 screws, and separate the metal and plastic pieces from the thermal cutoff.
  6. Ovente Electric Kettle KS88 Series Disassembly: passo 6, immagine 1 di 2 Ovente Electric Kettle KS88 Series Disassembly: passo 6, immagine 2 di 2
    • Open the plastic box to examine the thermal cutoff insides.
    • This piece is replaceable as a whole component. Disassembly here isn't a necessity.
    • Remove the small white piece.
  7. Ovente Electric Kettle KS88 Series Disassembly: passo 7, immagine 1 di 1
    • Remove the two remaining connected black wires from the heating element by jiggling and pulling outwards.
  8. Ovente Electric Kettle KS88 Series Disassembly: passo 8, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 8, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 8, immagine 3 di 3
    • Take off the handle.
    • Use a spudger and an opening pick in the seams to loosen the sides and bottom of the handle cover.
    • To remove the top, push the handle cover into the kettle and slide up to remove.
  9. Ovente Electric Kettle KS88 Series Disassembly: passo 9, immagine 1 di 1
    • Remove the button from the kettle.
    • Remove the gel stabilizer piece.
  10. Ovente Electric Kettle KS88 Series Disassembly: passo 10, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 10, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 10, immagine 3 di 3
    • You should now be looking at the open circuitry of the kettle inside of the handle.
    • Disconnect the wires from the micro-chips by gently pulling using your thumb and forefinger.
  11. Ovente Electric Kettle KS88 Series Disassembly: passo 11, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 11, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 11, immagine 3 di 3
    • Unscrew the bottom chip and take it out of the handle. Use a #1 Phillips screwdriver to take out the 8.2 mm screw.
    • Then, weave it out the wires that were connected to the heating element and the thermal cutoff assembly through the handle base.
    • Remove the chip and it's soldered wires from the handle completely.
  12. Ovente Electric Kettle KS88 Series Disassembly: passo 12, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 12, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 12, immagine 3 di 3
    • Weave out the black coated white wire through the base of the handle.
    • Carefully unhook the LED attached to the base of the kettle.
  13. Ovente Electric Kettle KS88 Series Disassembly: passo 13, immagine 1 di 2 Ovente Electric Kettle KS88 Series Disassembly: passo 13, immagine 2 di 2
    • Remove the two 19 mm screws from the top of the handle using a Phillips #2 screwdriver.
    • Take off the handle by pushing down on the button and pulling the handle towards you.
  14. Ovente Electric Kettle KS88 Series Disassembly: passo 14, immagine 1 di 1
    • Remove the temperature sensor from the bottom of the kettle.
  15. Ovente Electric Kettle KS88 Series Disassembly: passo 15, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 15, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 15, immagine 3 di 3
    • Using your thumb, push up on the bottom of the microprocessor to remove it from the handle.
  16. Ovente Electric Kettle KS88 Series Disassembly: passo 16, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 16, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 16, immagine 3 di 3
    • By using your fingers or a spudger, disconnect the button interface (cover) from the processor.
  17. Ovente Electric Kettle KS88 Series Disassembly: passo 17, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 17, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 17, immagine 3 di 3
    • Using a #1 Phillips screw driver, loosen the 8.5mm screw on the processor chip and separate it from the plastic base.
  18. Ovente Electric Kettle KS88 Series Disassembly: passo 18, immagine 1 di 2 Ovente Electric Kettle KS88 Series Disassembly: passo 18, immagine 2 di 2
    • Remove the screw from the inside of the lid.
    • Remove the metal cover from the plastic part of the lid.
  19. Ovente Electric Kettle KS88 Series Disassembly: passo 19, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 19, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 19, immagine 3 di 3
    • Use the pointy side of the spudger to push the metal rod through the spring and out of the cover.
    • Make sure to catch the spring if it pops up.
    • Remove the lid from the kettle.
  20. Ovente Electric Kettle KS88 Series Disassembly: passo 20, immagine 1 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 20, immagine 2 di 3 Ovente Electric Kettle KS88 Series Disassembly: passo 20, immagine 3 di 3
    • After removing the lid, push down on the inside plastic piece and push up on the outside of the remaining plastic part to remove it from the kettle.
    • We are left with the metal kettle stripped of all its circuitry and mechanisms.
  21. Ovente Electric Kettle KS88 Series Disassembly: passo 21, immagine 1 di 2 Ovente Electric Kettle KS88 Series Disassembly: passo 21, immagine 2 di 2
    • Here is a picture of the heating element which cannot be removed from the kettle.
    • The circuit schematic for the kettle is shown here as well.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 64
Tutti i Tempi: 3,109
