Salta al contenuto principale
Oven Heating Element Replacement
Cosa ti serve
  1. Oven Heating Element Replacement, Element: passo 1, immagine 1 di 1
    • Before purchasing your replacement element, make sure it matches the size of the first element.
    • The element may not fit inside the stove if it is not the appropriate size.
  2. Oven Heating Element Replacement: passo 2, immagine 1 di 2 Oven Heating Element Replacement: passo 2, immagine 2 di 2
    • Go to your electrical panel and turn off the power to the stove.
    • WARNING: Do NOT attempt any of these next steps with the power on.
  3. Oven Heating Element Replacement: passo 3, immagine 1 di 2 Oven Heating Element Replacement: passo 3, immagine 2 di 2
    • Open the oven door and unscrew the 5 mm Robertson head screws that keep the element in place.
    • In most cases, there will be two or three screws to remove.
    • Make sure you check the screws thoroughly in case there are more.
  4. Oven Heating Element Replacement: passo 4, immagine 1 di 3 Oven Heating Element Replacement: passo 4, immagine 2 di 3 Oven Heating Element Replacement: passo 4, immagine 3 di 3
    • Using your voltmeter, place it on the two wires to make sure there is no electrical current.
    • Gently pull out the element two or three inches to expose the connecting wires.
  5. Oven Heating Element Replacement: passo 5, immagine 1 di 3 Oven Heating Element Replacement: passo 5, immagine 2 di 3 Oven Heating Element Replacement: passo 5, immagine 3 di 3
    • Mark down the coloured wires and how they are connected. You will need to match them by color when you reconnect the element.
    • It may be helpful to take a photo of the element with the wires still connected. This will make reconnecting it easier.
    • Remove the screws holding the wires in place.
  6. Oven Heating Element Replacement: passo 6, immagine 1 di 1
    • Remove the damaged element from the stove. It should slide out easily.
    • If possible, try to locate where the damage on the element took place for future reference.
    • Begin installing the new element.
  7. Oven Heating Element Replacement: passo 7, immagine 1 di 2 Oven Heating Element Replacement: passo 7, immagine 2 di 2
    • Connect the power wires by matching the same color as the original element. (Refer to Step 5 for more information.)
    • Gently re-insert the element back into the stove opening.
    • Refasten the two screws at the front to secure the element in place.
  8. Oven Heating Element Replacement: passo 8, immagine 1 di 1
    • Close the oven door and reset the power through the electrical panel.
  9. Oven Heating Element Replacement: passo 9, immagine 1 di 1
    • Turn the power on and turn the oven on to make sure the element is functioning properly.
    • There may be some smoke and an odor coming from the baking element because of the protective coating. This is normal.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 170
Tutti i Tempi: 2,664
