Salta al contenuto principale
Outdoor Gate Deadbolt Replacement
Cosa ti serve
  1. Outdoor Gate Deadbolt Replacement, Deadbolt: passo 1, immagine 1 di 3 Outdoor Gate Deadbolt Replacement, Deadbolt: passo 1, immagine 2 di 3 Outdoor Gate Deadbolt Replacement, Deadbolt: passo 1, immagine 3 di 3
    • Remove the old deadbolt.
    • The gate should look like this before you begin installing the new deadbolt
  2. Outdoor Gate Deadbolt Replacement: passo 2, immagine 1 di 3 Outdoor Gate Deadbolt Replacement: passo 2, immagine 2 di 3 Outdoor Gate Deadbolt Replacement: passo 2, immagine 3 di 3
    • From the front side of the gate, push the latch into the center of the opening. Adjust as needed.
    • Screw both of the short screws into the panel to the right of the latch.
  3. Outdoor Gate Deadbolt Replacement: passo 3, immagine 1 di 3 Outdoor Gate Deadbolt Replacement: passo 3, immagine 2 di 3 Outdoor Gate Deadbolt Replacement: passo 3, immagine 3 di 3
    • Grab both of the long screws.
    • Adjust the back head of the doorknob to be facing in a straight upward position.
    • Screw in the long screws.
    • Make sure the screws are properly tightened.
  4. Outdoor Gate Deadbolt Replacement: passo 4, immagine 1 di 2 Outdoor Gate Deadbolt Replacement: passo 4, immagine 2 di 2
    • The back end and the front face of the deadbolt must line up.
    • Screw in the screws until they are fully tightened.
  5. Outdoor Gate Deadbolt Replacement: passo 5, immagine 1 di 2 Outdoor Gate Deadbolt Replacement: passo 5, immagine 2 di 2
    • Test out the new deadbolt with a key or door handle, depending on which one you may have.
Conclusione
Kenneth
Membro da: 03/20/24
121 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 152
Tutti i Tempi: 1,742
