Salta al contenuto principale
Ottlite PL-0094 Lamp Switch Replacement
Cosa ti serve
    1. Ottlite PL-0094 Lamp Switch Replacement, Remove Switch: passo 1, immagine 1 di 1
      • Lay lamp on its side and remove the 2 screws between the lower and upper lamp posts. Gently pull the 2 sections apart a few inches. Slide the plastic switch cover off by sliding upwards.
      • Remove the 2 screws holding the USB port circuit board to the cover.
      • With utility blade, carefully cut the 2 plastic mounts for the touch switch circuit board and remove from cover.
      • The small flat on/off button should fall out also.
      Chiedi a FixBot
      Aggiungi Commento
    2. Ottlite PL-0094 Lamp Switch Replacement, Mount New Switch: passo 2, immagine 1 di 1
      • I mounted the new switch in the location of the old switch button. There is a hole mostly there already if you just cut the remaining plastic to leave about a 3/8" hole.
      • You'll need to trim down the small plastic posts that held the switch circuit board in place.
      • The switch doesn't have a lot of threads, so you can't use thick washers. I used a 5/16" speed nut on the inside, which also helps keep the switch centered since hole is a little bit bigger than needed.
      • On the outside I used a thin plastic washer, then the nut for the switch.
      • Bend the tabs down as pictured so wiring will fit when reassembled. Tighten nut.
      Chiedi a FixBot
      Aggiungi Commento
    3. Ottlite PL-0094 Lamp Switch Replacement, Wiring: passo 3, immagine 1 di 2 Ottlite PL-0094 Lamp Switch Replacement, Wiring: passo 3, immagine 2 di 2
      • Since the the touch switch doesn't work, we discard that circuit board. Cut the 4 wires at the circuit board.
      • I soldered my wires together and covered with shrink tubing. I suppose you could use good insulated wire connectors instead.
      • Connect the 2 black wires together, the one from the USB board to the one going to the lamps.
      • Connect the red wire from the USB board to one of the switch wires. I used the red switch wire.
      • Connect the other wire from the switch to the white wire going to the lamps.
      • Screw the USB board back in place.
      Chiedi a FixBot
      Aggiungi Commento
      • Feed the wires back up into the lamp post holes. Fold wires so they fit inside cover as you slide the cover back in place.
      • Fit the 2 lamp posts together and install the 2 screws to hold them together.
      • Plug in, and hopefully your light now works.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Enjoy!
KenF
Membro da: 10/31/23
139 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 27
Ultimi 30 giorni: 83
Tutti i Tempi: 1,601
