Salta al contenuto principale
Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement
Cosa ti serve
  1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement, Top Panel Removal: passo 1, immagine 1 di 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 2, immagine 1 di 3 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 2, immagine 2 di 3 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 2, immagine 3 di 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 3, immagine 1 di 2 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 3, immagine 2 di 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 4, immagine 1 di 2 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: passo 4, immagine 2 di 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
Conclusione
USF Tampa, Team S7-G5, Passmore Spring 2018 Membro di USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 513
