Salta al contenuto principale
Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement
Cosa ti serve
  1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Removal: passo 1, immagine 1 di 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 2, immagine 1 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 2, immagine 2 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 2, immagine 3 di 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 3, immagine 1 di 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 3, immagine 2 di 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 4, immagine 1 di 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 4, immagine 2 di 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: passo 5, immagine 1 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: passo 5, immagine 2 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: passo 5, immagine 3 di 3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 6, immagine 1 di 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 6, immagine 2 di 2
    • Remove the two 11mm Phillips #1 screws from the top cover.
  7. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 7, immagine 1 di 1
    • Use spudger to pop the control panel out.
  8. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 8, immagine 1 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 8, immagine 2 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 8, immagine 3 di 3
    • Remove the four 11mm Phillips #1 screws from the control panel.
  9. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 9, immagine 1 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 9, immagine 2 di 3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 9, immagine 3 di 3
    • Remove the two 11mm Phillips #1 screws from the button panel.
    • Flip the screen assembly over and remove the button panel.
  10. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 10, immagine 1 di 2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 10, immagine 2 di 2
    • Remove and replace buttons as necessary.
Conclusione
USF Tampa, Team S7-G5, Passmore Spring 2018 Membro di USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 254
